Surge used to be my favorite AA light, it is bright, beam is smooth and pretty good runtime until I got the 5W Cyclops from Lambda.
Although Lambda told me that rings won't be problem on 5W SE LS, I was a little hesitated due to the poor nature of Mag reflector. I was proven totally wrong. The 5W Cyclops not only outthrow the Surge, yes, it outthrow our very favorable Surge albeit not too much. Surge is very yellow, wait, isn't Surge beam pretty white and smooth? Not when compare with Lambda's 5W Cyclops, the 5 Watter not only outthrow the Surge a little bit, its beam and spill is even smoother than the Surge. No rings or any artifact at all, not a bit. In fact, its beam pattern is very similiar to Ultra Stinger w semi-smooth reflector but only a little dimmer.
I run the 5W Cyclops continously for an hour, I couldn't see any drop in brightness (compare w freshly charged batteries on Surge). I don't have patient to try to run it down. I guess it will maintain its brightness for a couple of hour and start to drop and last forever.
I like Surge so much that I have 3 of them. It's sad that I have to retire them and keep them as *old* collection. I still could tell friends that these light used to be the brightest AA light available.
What will be the next? With lambda's excellent heatsink, I guess 8AA (NiMH) might be the next move if the body that fit 8AA could be found. Or 8AA with step down regulated for constant brightness?
Great work, Kevin
Alan
Great work, Kevin
Alan
