hi everyone,:wave:
i have been lurking here since 2003 but never registered to post. From the CPF forum, i have learned a lot about the technology involved in making a good flashlight and have spent a fortune on LED/XENON/HID lights!!!
decided to post my 1st post here because my friend, Dreamer, has asked me to share more info here about an LED light that, according his words, should deserved more attention.
so here goes....
the LiteFlux LF1 Version 2.0 uses a T bin Luxeon III & comes with 2 bodies (1AA & 2AA)
as far as i know the LiteFlux LF1 V2 is made in Taiwan. Not China (i am not trying to imply anything negative if it is made in China, i own a few china well made lights!)
the many differences between Version 1.0 & 2.0 are as follows.
LF1 V2 has a more stable tail standing ability. i.e. tail press button does not protude out.
Removeable Stainless Steel cosmetic ring added to the body and extention tube of LF1 V2.
LF1 V2 comes installed with a black silicon tail button AND a spare red one. V1 only has a black one installed. no spare.
The holster has been improved so that it fits both 1AA & 2AA configuration.
the holster belt loop is velcro attached. not stitched.
LF1 V2 circuit has been improved to give slightly longer runtime in both 1AA & 2AA configuration.
2 important & new features added to LiteFlux LF1 V2 are
first, a true momentary clickie tail switch & :goodjob: :rock:
i have a surefire Z48 HA switch and i can honestly say that the operation and switch travel of the LiteFlux's 2 stage true clickie is quite similar to the Z48.
you press in about 1mm to turn on and press a further 2 - 3mm to click on.
second, hi & low 2 stages by twisting the tail cap. (low is somewhere around 5 - 10% with my not so scientific eyeballs) :goodjob: :twothumbs
hi / low is activated by twisting the tail cap 1/8 to 1/4 turn. lock out is achieved with 2 - 2 1/2 turns.
there are 3 methods/modes to use the 2 stage tail cap.
high mode - fully tighten tail cap. press or click button you get high beam. twist for low.
low mode - loosen tail cap 1/2 to 1 turn. press or click button for low beam. twist for high.
low mode with momentary high - loosen tail cap about 1/8 turn.
press lightly, you get low. press further, you get high. press even more and the light clicks to low. while click to low, you can press the button to get momentary high.
:naughty:
finishing is claimed to be HA III black. but i have no way to test its hardness. feels nice in my hands though and my friends say they preferred the look and feel of the anodizing. :shrug:
you can rotate the bezel for flood or spot or you can remove the bezel and use the light as a candle ( just like a
M@g 2AA) BUT with hi / low output!
By the way, all the parts (LED engine/brass heat sink, reflector, glass lens, 2 stage contact ring, clickie switch) are removeable with the correct simple tools. None are epoxy or seal.
well quite a long first post. gotta go. any questions i will try my best to answer. thanks.
LED Cool
