petrev
Interest - 2nd Run THE ORIGINAL SF-M6 XTN 36 Tube for Regulated 4800mAh HDM6 (Or PIR) Packs
Original Thread
XTN36
36mm Extension Tube to fit SureFire M6 *Length see Note*
- Allows 4800mAh Regulated-Rechargeable Battery Packs to be used with the SF M6
- Gives ~60min MN21 HOLA Total Runtime
- Fully Reversible
- Direct-Swap use of MN20 and MN21 bulbs - XTN36 is designed to fit with the AWR-HD4800 regulated packs.
- Plus the added capability to also be set to use MN20 plus other HOLA+ options as required.
- HD Soft-Start for extended bulb life
- 36mm is shorter than 52mm
- 0mm is shorter than 26mm
- HD4800 Packs +Chargers Available from AndrewWynn here
The XTN36 is designed to fit with the AWR-HD4800 regulated packs that allow instant-swap use of MN20 and MN21 bulbs with the added ability to also be set to use MN20 plus other HOLA options as required.
Example - The XTN36+HD4800 pack allows the use of the Osram 64275AX Super HOLA without undue cell stress plus std. MN20 LOLA
Express you Interest
XTN36-GR.6082 is HAIII Grey made from 6082-T6 Standard Hardness Aerospace Aluminium Alloy (Vickers Hardness 95) Medium/High Tensile Al-Alloy (max-310MPa) source:(MatWeb)
Original Thread
XTN36
- Fully Reversible
AWR - AndrewWynn is currently offering an HD-M6 mod. here with a Hotdriver and a 3300mAh rechargeable pack.
I have been exploring with him, my local machineshop, and an anodising company the idea of offering a super-power version using a 40mm extension tube and a 4800mAh battery pack. This extension will allow either an AWR-HD or a PIR1 regulator to be fitted.
This is how the conversation started . . . here from #115 (my PIR-M6 Tester and MN21-Osram35AX mod are slightly earlier in the thread + all the background to the HD-M6/PIR)
How about a 4800mAh super-pack option ?
I've been looking into getting 40mm extension tubes made for the M6 - Aircraft alloy, sympathetic design and HAIII hard anodised.
With these extension tubes you could just lengthen your pack to 3p2s-17670 protected AW-1600mAh and have room for an HD or a PIR1 utilising your New-TailCup. AWs 17670s are listed at the same price so for a little more we get a bump-up from 3300 to 4800mAh !
I can get them made and send them to you for inclusion with a super-pack upgrade if you wanted to do this depending on response. I would need 10 units to start this off as the CNC machine setup cost is the biggest factor.
10 gives a starter figure of £35( ~$62) per (including anodising +postage) - This is based on their guess of how long it will take to setup the CNC-Machine from my M6 and could be slightly more or less but seems reasonable.
So - to sum up - for about $62 (EDIT:Now inc. post) we can add another 20minutes runtime to the HOLA-HDM6 / PIR1
~$12 per 20minutes-HOLA Std. dimming Primaries (SF batteries)
~$120 ~ 40minutes-HOLA Regulated(+100%) 3300mAh Li-Ion
~$180 ~ 60minutes-HOLA Regulated(+200%) 4800mAh Li-Ion
So - Who wants one (or two?)
Please Express your interest and any questions
Pete
*PLEASE NOTE: 36mm is the Nominal Length (Body-End to Tail-Shoulder=36mm) and should not be used as mission critical datum - actual extension / overall M6 length must be determined from actual M6 +XTN +4800 used (Total Overall Length increase less than ~39mm including internal options).
