LED_ASAP
A few people have posted various LED-mods on Mag Solitaire---most of them use tiny, low capacity 12V batteries. I am not too satisfied with the results. I want to have something similar to Arc AAA's---
1) use single AAA battery
2) doesn't need to be blindingly bright, but should have enough light to read or walk around with
3) good battery life, at least 5h.
4) fit in Mag Solitaire casing, and use the same twist on and off control
5) non-destructive mods, if possible
After some careful planning, I think one option is to fit a mini booster into the space for the bulb socket, about 6mm diameter and 8mm long.
I was able to build a prototype device using a 3mm Nitcha LED, a transistor, a resistor, and a small transformer/inductor made by winding a few turns of enamel wire on a ferrite core. But the mini booster soon failed after being filled with epoxy glue:-(
A painful troubleshooting revealed that the ferrite core I used was to be blaimed---I used a 3mm section cut out from a longer ferrite core (JW Miller Magnetics, model number FB73-422, 11mm in length and 5mm in outer diameter, ordered from Digi-Key, part number M2308). I realized that this particular ferrite core was designed to be used as a choke in power supply lines, and IT IS CONDUCTIVE!
There is no space to put in any insulating material before winding the enamel wires through the hole, and the conductive nature of the ferrite core means if the insulating enamel coating ever get broken, the ferrite core will short out the wires---in one word, the reliability of the entire booster hangs on a few micrometer thickness of enamel coating!
I am still trying to find other suppliers of the ferrite core---non-conducting ones---and I am surprised to see how difficult it is to find any so small!
Does anybody have spare cores or know where I can get a cheap mail order? (BTW, I live in Canada(/_\)
Any ideas on alternative Solitaire mod are welcome!
