I was taking the Opalec out of my minimag and the plastic legs broke off and stayed in the mag. I hear Opalec has had this happen before and they have good customer service and will replace, but I figured what the hey, this will allow me to try some other configurations out.
First I put it in a Brinkmann with clicky tail switch. The opalec and "pusher" fit fine but when you tighten down the head stop tightening as soon as the pusher makes contact or it will twist the opalec unit and therefore the wires underneath. You might want to then tape or glue the head in place so it wont get accidentaly tightend.
After straiting the wires I put it in a Rayovac adventure Kids lamp. I had to grind off the ring where the bulb goes in but then you just push it in like a regular bulb. I had a 50/50 chance of getting it right on the first try so needless to say it only took me three tries.
I then put some hot glue to hold it in place a little firmer. Probably not neccessary. I also enlarged the hole on the reflector. The reflector adds more light but in the form of funky swirls and botches. I might just leave it out.
Anyhow I think I'll just use it like this for now. I have another opelec in a mag anyway.
I think you could easily fit two oplecs in this one unit but I didn't do any wiring or want to put $50 worth of parts in a $5 light
Tip: You might want to lube your opalec legs before you insert into the mag.
