PsycoBob[Q2]
- Joined
- Apr 9, 2002
- Messages
- 518
Ok, I pulled apart my home-made Zorch-copy to get the nicely mounted LED for this one.
3D mag as the donor body, with a 6AA (3long, 2 wide) holder with custom electrodes. Brighter than any of my stock Mag-3D's.
That's the battery pack. The other side is below.
The brown goop is dried gasket adhesive (rubber cement analog)
The ÜberZorch next to my Intellimouse Explorer.
Beamshots- taken 8 feet from the ceiling. First is the Zorch, then side-by-side with a Mag 3D, then superimposed beams. [edit] now color-corrected.
Note: in the beamshots, the Mag's reddish beam is actually the normal yellow. The brightness of the Zorch screwed the camera's white balance, and I haven't had time to edit the pics to normal coloring.
Unfortunately, I have no light-meter.
[edit] new pics. The output end, with reflector, then with head removed to show PCB and Aluminum disk.
