will there be such a light?(commercially)
chesterqw
singapore,jurong
i want a light like this....i think you will too :p
so my list goes like this
1) around same size as the l4
2) uses luxIII U bin at 900ma.
3) reflector!!!(around the same size as the l4's)
4) have haIII coating and is made of good quality metal(surefire,jet-I kind)
5) uses either 18650 or 17670. can be used with 2xcr123 too.
6) clicky tailcap.
7) 2 to 3 stages of brighness :)(really optional, can not care about)
8) around the price of the L4 here.(150?)
plz don't tell me any light that is made by modders unless i can buy one.
Long John
Spain, near Cadiz
Hello chesterqw:)
No chance to get a stock light in this configuration IMO.
But why not such a light made by one of the great modders here at CPF?
I would post your question at "Homemade and Modified lights".
Best regards
_____
Tom
Hoghead
Minnesota
It sounds like you want a KL1 modded by Chop with a reflector. He can also change the drive circuit to give you the 900ma or close enough one way or the other to meet your requirements and use a U bin Luxeon.
I would send Chop a PM with questions before you spend any money. He can tell you if he can mod a E2L or if you need a generation one KL1, etc. He can also tell you how much it will cost.
You also might ask him if you should use a Aleph head instead of a KL1.
He might be able to supply the needed parts. That way you would only need to send him the money for your light.
I hope this helps. Good luck!!!
