OK, I pretty much had myself convinced that there was no way a 5 watt Luxeon would work decently off of 2AA cells. But, things be as they are, I just couldn't stop thinking about it. After much experimenting with converter design after converter design, I finally came up with one that is fairly promising. The 2AA Brinkmann makes for such a nice small flashlight I couldn't resist the urge to try it with a 5W at least once.
After getting the mod together I was quite surprised to find that the 5W SE really doesn't focus to a sharp beam too well compared to the 1W SE. The large die size of the 5W puts most of its surface area outside of the focal point of the small AA reflector. It does however make for a very broad and smooth beam, almost more like an area light than regular flashlight beam.
You can see from the photo this is one very white Luxeon, and is plenty bright for the broad beam it throws out. It really lights things up in a smooth even pure white light. The larger picture is using AA Lithium batteries for a little extra brightness, and the two inset pictures show it using alkaline AA cells. No run time tests yet as the thermal epoxy needs to set up completely before I take it for a long test drive. I would expect 45 to 60 minutes of runtime depending on the batteries used.
I've been wanting something with a bright even light to use when working with the lathe to help see fine details. I think this light will come in handy for that purpose and others.
Merry Christmas all!
