Curious, I'm looking at installing a belt clip on aluminium flashlights. (i.e. Like the Spyderco knives.) Can I just do a Dremel set up on a small drill press to drill the holes into aluminium bodies, and then tap the holes?
Is the Dremel too high a RPM? What bits would I use if it is possible? And do I need to tap it or can I just use high quality screws to 'create' the threads as I screw it in?
(Does my question even make sense?)
I may end up just sending it to McGizmo who does absolutely incredible mods but thought I may try my hands at such a simple mod.
Thanks,
MO
Thanks,
MO
