3D Mag, EverLED and 6 or 7 AA NIMH's ????
Face
Hi,
I was just wondering if this would work or if anyone could see any problems or reasons why it wouldn't work.
I have a 3D Mag fitted with an EverLED, which can be fitetd into any Mag.
Now, what I would like to do is run it on multiple AA NIMH (Energizer 2500's) cells; either 6 or 7 of them, depending if you can get 4AA to D converters.
So, would this work? If so, does anyone know where I can get the necessary AA-to-D converters from, along with a dummy D cell? Preferably from the UK - I've tried a Google, but haven't managed to find anything locally, tho.
Any help or advice that you may have would be very gratefully received.
Many thanks in advance for your time,
Face
evan9162
Boise, ID
The everLed is only rated for 6 cells. Even though rechargables say "1.2V", this doesn't mean that 7 cells will be under the 9V. NiMH cells are 1.4-1.45V/cell freshly charged, so using 7 cells would be 9.8-10.15V fresh, and you would be exceeding the maximum voltage for the everLed. Stick to 6 cells.
Brighteyez
San Jose, CA
Look for a vendor under the name of Litemania in the Dealers Corner forum of this site
http://candlepowerforums.com/vb/forumdisplay.php?f=13
He gets these in (and sells out of them) on a regular basis. They're $3 USD each and he charges $5 for flat rate registered mail shipping from Korea.
Get extras in case you break them or short them out (they're easy to reverse polarity with as the positive and negative poles are easy to reverse if you're not careful.)
Face said:
Hi,
Face
Face
Thanks very much for the replies and information.
I take it I would need "series" adapters?
Thanks again,
Face
Phaserburn
Connecticut, USA
3 alk D cells in a Mag running an Everled will get around 30 hours or so IN regulation. Why would you want to mess with AA nimh that self discharge and adapters in this setup? It's like going all the way around your arm to get to your elbow...
Long John
Spain, near Cadiz
Hello Face:)
When you want to change to AA-cells, I would go with a 2-D model.
It depends where you live, but for about 10-15$ in the USA?
Best regards
____
Tom
PlayboyJoeShmoe
Shepherd, TX (where dat?)
What they said to a large degree...
I have NimH in all my Superbulb lights. I don't use these lights very often, and so self discharge is a problem.
All my "user" LED lights (M*gleds, Craftsman 1W, SMJLED PR etc.) have Alkaline.
It just wouldn't do to have my near the door emergency lights self discharge to death.
I can't feature actually carrying and using a 3D in the long term. So I'd leave some big juicy D cells in there and mess with something else!
Oh! My HOT climate (car interior, garage etc.) lights have Lith AA, AAA and 123 as I have had WAY too many leaky alks here in Texas!!!
Face
Hi again
Think I probably will stick with Alkaline AA's, after all.
Just thought it would be useful to have, in effect, a 6-cell EverLED running in my 3 cell light. Not too worried about runtime, just pure output.
Thanks again,
Face
Phaserburn
Connecticut, USA
You won't get more output using 6 AA cells. The sweet spot is 3 cells. More than that justs wastes energy bucking the voltage down.
Face
Oh. Really? That's a shame. I thought it would work.
I thought the output went up, the more cells you used. Is this not the case, then?
Cheers,
Face
Phaserburn
Connecticut, USA
No. Output tops out at 3 cells. As it's a 3 cell body you're using, that's why I suggested going with the D cells. Best combo of runtime/output.
Face
Oh well, never mind...
Saved myself some money on converters then, i guess :)
Thanks again,
Face
