A week back I installed an EVGA FX5500 AGP card into my older box. It was working okay until the other night when it went into a suspend/sleep mode while I was online.
When I boot into safe mode, it will give me the 640x480 screen but when I try a normal boot, right after the splash screen, it will go into a suspend mode and it not come out. I can see that the HD activity indicator continues to boot and the MSI mobo LED's does not indicate a hardware issue.
The drivers are Forceware V 81.98 for 98SE/MEand I've tried the EVGA and regular NVIDA drivers. When I try to remove the program in the add/remove section, I get an illegal operation error message and it terminates.
Since the old Sparkle 300W PS was marginal, I replaced it with a Cooler Master, Real Power 450. I would not think it is a PS related issue.
Even on my clean back-up drive which had a smooth driver install, I have problems. That drive is sterile from the net, and holds the basic OS and photo data.
Thoughts?
Thoughts?
