ledfanfromjuno
I just tried out my new madmax. I widenned the lip of the minimag as the illpill installation instructions suggest so no contact with the lip occurs with the terminals to the luxeon as the sandwich is rotated in the body.
I noticed that it makes a difference what minimag color you choose to install the madmax into. I use a low voltage setting on the madmax sandwich and at this level of light the minimag's body color has a pronounced effect on the light output, at least it seems to to my naked eye. I have silver and purple minimags. The purple puts out a slightly purple beam and it is noticeably darker than the brighter silver beam. It's more than luxeon diversity. It is darker as it is purple. The collimator must be picking up a lot of the light reflected off the inside of the head. The purple head doesn't reflect as much light as the silver.
I also adjusted the voltage on the trimpot. I got an opalec newbeam and turned it on and adjusted the madmax till its output was equal to the newbeam. Then I slowly increased the voltage on the trimpot until light increased above the newbeam. The light really jumps from newbeam level to 2 or more times newbeam level with just the slightest turn. I'm going to keep my madmaxes set at this level, which is about 1/3 to 1/2 the light output of my arc ls hybrid second. I'm now going to charge a fresh set of 1850 mah kodak nimh AA's and see how long the madmax will stay in regulation for.
I really like the madmax. I really like the fact that it's adjustable. It does maintain regulation well for nimh batteries according to the plot at wayne yamaguchi's shop. It is the alkalines that have a horrible regulation curve with this sandwich. Since I use nimh only it doesn't affect me. I didn't like the kroll or ram tailswitches. The minimag tailcap works good enough and seems more durable to me. I had problems with the other switches I don't want to go into here because of time. I'm now eagerly waiting for my mineral glass lenses.
If these madmaxes on low voltage give me 3 to 4 hours of runtime with these batteries then I will be very pleased.
