I've been looking for ways to improve on the NX05 optic lately and have been very satisfied with the results I've achieved. But, even though I can get much smoother, more even beams, the overall size and dispertion angle of the beam remains the same.
In the midst of all my testing, a kind and generous fellow CPF'er offered me the opportunity to test the McFlood reflectors. I had seen the McFlood while surfing for flashlight parts, but never really knew enough about them to really jump at getting one.
All I can say is Wow! I can't believe I never discovered these before!
They are a perfect fit for any Luxeon mod that uses a stock collimator. They can fit in LS/o's since they have the same lip, or even in a Brinkmann or Mini-mag AA.
In the photo below are a pair of nearly identicle Brinkmann 3AA batwing mods (built from the same reel). The light on the left sports an NX05 collimator, and the McFlood is on the right. The lights were placed about 8 inches from the wall as this was the best comparison that the camera could pick up. Regretfully, beam color is about all that was properly reproduced by the camera. A new digi-cam is in the works, so yall won't have to put up with my crappy pix much longer..
The thing that's most striking about these reflectors is how they can create a "whole new flashlight" out of an identicle twin. I have yet to find any other solution that creates such a smooth evenly distributed beam. The McFlood seems to turn the beam "inside out" in a way that improves the color dramatically. These two luxeons looked the same color before the McFlood was installed. I'm thinking this reflector will be useful for times when I get a Luxeon that has a blotch or color defect.
What the photo really can't convey are the many uses for this light. Make no mistake about it, you won't be using the McFlood at ranges greater than 8 feet. But while the McFlood gives up range, it TOTALLY dominates the close task uses for a flashlight. The light can be easily used at ranges of just a few inches up to a few feet and still get an even light spill.
This light is ideal for working in small areas - like from inside of computers all the way to under the hood of a car. A person can now actually use a luxeon up close without an uncomfortably bright hotspot. Here's a shot of everyone's favorite book in a completely dark garage holding the light about 14 inches away..
In my tests I tried an SE, batwing, and lambertian emitter. The SE thew an even wider flood than the batwing, but with artifacts. The batwing is my favorite as it makes a smooth, even disk of light with a corona, The lambertian exhibited a beam similar to the batwing, but also included a slightly pronounced hotspot. You won't have to waste lux on diffusive lens coatings with the McFlood either.
You can find them here - about halfway down the page..
The best way I can sum up the McFlood is to say that any halfway serious Luxeon modder should try at least one.. It will give you a kind of light that you probably never had before. The more I use this light, the more I like it. I might also add that I'm the kind of person who likes tools that are specifically suited to a task. I have plenty of oustanding long range lights, now I have one that kicks a$$ at short range too.
