MikeHunt79
I'm going to be basing this setup about the 50w osram irc bulb. I've found a local supplier for these, so I'm gonna buy a couple of these. I've also already ordered a few mineral glass lenses from fenix store which should be coming over the pond quite soon.
Next, batteries. I plan on stuffing 12 x AA's in a 3D mag to give me 14.4v which is meant to work well with the 50w IRC. I'm going to order some 2700MaH Vapex batteries as the fit 4-in-a-row, and they also held up well to a 5a load in silverfox's battery tests, and the bulb shouldn't pull much more than 5a even tho it's overdriven.
I'm gonna be soldering up the battery pack myself as I'm using an un-bored host, and I want as little resistance as possible with this setup. Which leads me onto the bulb holder.
The KIU socket is meant to offer low resistance isn't it?
Or is it not that much different from the ceramic bi-pin bulb adaptor. Also will both of these holders work with the IRC bulb as this bulb seems the new kid on the block. I want to go for the KIU really, but they're outta D size ones at the moment.
Finally, the reflector. I'm probably gonna go for a LOP reflector, but I think you can only use a cammed one with the cermic adaptor? Or is this wrong? I quite the idea of a cammed setup.
Are there any other things I need or bit's I've forgot? Any other options I've missed... This is my for mag mod so I need everything going for me.
