Mihlrad said:
what can you really do with a collection of flashlights? Dont they all do the same thing? . . .
Most of mine do distictly different things.
McLuxIII-PD: a single lithium cell flashlight that can also use a rechargeable cell. It has two brightness levels that are good for walking in a dark place or looking into the distance (say 100 ft away). It is small enough for me to carry in "dressy" environments like meeting with clients, etc.
Night-Ops Gladius: a waterprof combat flashlight with a strobe. It has a runtime of 400+ hrs on low, which is enough light to read by or walk around by if it is really dark. It has a bright main beam and a strobe feature which is useful for hostile encounters.
SureFire A2 (red): a flashlight with red LED low level and bright incandescent high level. This is my nightstand light, sleeps next to my .45. The red low level is great for checking things at night without blowing my dark-adapted vision. If I want the bright main beam, I just push the tailcap switch harder: push for red, push harder for bright white.
Cyan Aleph3: a custom McGizmo light with a cyan LED. I use this for checking inside drinking water tanks when they are full of clear water. White light doesn't penetrate water that well, but cyan does a better job.
Red-Orange Aleph3: a custom McGizmo light with a red-orange LED. 140 lumens of red light. Not something you want to try to read by. I used it for some experiments with smoke and fog penetration. It works pretty well.
SureFire L2: a 2-level LED light with a floody beam. I use this for my volunteer fire service. The bright flood helps illuminate things like uneven ground when we are moving a patient on the gourney to the ambulance. Its smal size lets me keep it handy. The dim level is good for reading by. Other lights that are better for checking things in the distance are not well suited to area lighting.
SureFire M3 Combatlight: a flashlight designed for use with a pistol during hostile encounters. 225 lumens of white light and a strike bezel are really comforting when you actually think something bad is there. I use it for checking things in the distance too, 100 to 200 yards, r more when used with binoculars.
Photon Freedom: a really bright keychain light. I keep this in my jacket pocket and my backpack as a spare. It weighs nothing and takes up virtually no space.
Scott
