PoliceScannerMan
OK, what do you think about this, can it be done?
I just bought one of these 2 x 123 tubes:
I am planning on buying a Ti Aleph head from MoreLite. Its just an empty head.
His thread says i need the following:
McR-27 reflector
29.3mm window (lens) (I use a 1mm think sapphire one with the Ti bezel rings)
Aleph 1 retaining ring or 27mm bezel ring
#23 O-Ring
Aleph Light Engine of your choice or you can build your own with an E-screw, E-screw can, emitter PCB, LED emitter and converter of your choice.
I have a couple XX1S coming to me. I have never "Built a light by myself before, but you gotta start somewhere right?
What do I need to put in this set up to drive this X-bin to spec off of 2 x 123 (or R123). Can I even run a "Star" in an Aleph head?
So can this be done? I have a few tools and a soldering iron.... I have two X-bin stars, so i can mees up only once... :laughing:
McR-27 reflector
#23 O-Ring
