LEDninja
Recently a number of new SMJLED products have appeared and caused confusion both between the kind of LED (MJLED, CMJLED, CMJLED2, SMJLED3mm) and the kund of product (cut/uncut raw LED, PR2 base bulb, bi-pin bulb). I hope the discussion will help clarify the situation.
I am doing this from memory. There will be errors. Do not take this as Gospel.
Member who spot errors please post. Members who have bookmarked threads on the older items please post.
MJLED (ISP100mA die)
Most 5mm LEDs project light forward from the dome on top of the LED. Flashtights need the light to go sideways into the reflector. So one day eons ago MJ (EDIT: Michael Jorden (not the basketball star) CPF handle ARCmania /EDIT) ground the top of an LED almost flatto get the light to go sideways. The LED was an ISP 100mA .
MJLED CUT (BATCH 1)
The early LEDs has relatively higher Vf and require Lithium batteries (Energizer L91).
MJLED CUT (BATCH 2 and later)
Low Vf LEDs were selected allowing alkaline batterues to be used. There are reports Lithiums will burn out these LEDs.
http://theledguy.chainreactionweb.com/product_info.php?cPath=48_52_82&products_id=568
MJLED UNCUT
One can also by the ISP LEDs before they were ground down by MJ if wide angle beam not required.
http://theledguy.chainreactionweb.com/product_info.php?cPath=48_52_24&products_id=578
SMJLED (4 die)
A 4 die LED that is brughter than the original is used. It is called the Super MJLED.
SMJLED CUT
http://home.mchsi.com/~lambda_lights/smjled.htm
http://theledguy.chainreactionweb.com/product_info.php?cPath=48_52_82&products_id=754
EDIT: Wah Wang makes something very similar to the CUT SMJLED.
http://candlepowerforums.com/vb/showthread.php?t=113761&highlight=Wah+wang
SMJLED UNCUT
http://theledguy.chainreactionweb.com/product_info.php?cPath=48_52_82&products_id=755
SMJLED PR(2)
Comes in a PR2 bulb. A boost circuit helps extend battery life and allow use of NiMH. Mine dimmed at 2.2V. A raw MJLED would be iseless below 2.7V.
http://home.mchsi.com/~lambda_lights/pr2bulb.htm
http://www.lighthound.com/sales/arcmania_led_upgrades.htm
SMJLED2 (Cree Xlamp die???)
A Cree Xlamp die which is even brighter is used.
SMJLED2 BI-PIN (with boost circuit)
A bi pin version of the SMJLED with boost circuit for minimags will come soon. Manufacturer has all the parts, waiting for the phone call to start assembly.
http://candlepowerforums.com/vb/showthread.php?t=127907
EDIT Available now
http://theledguy.chainreactionweb.com/product_info.php?cPath=48_56_83&products_id=940
http://theledguy.chainreactionweb.com/product_info.php?cPath=48_56_83&products_id=950
EDIT: WPR2
The MJLED is a cool white and the SMJLED tint is more blue. TrueBlue sells a variant of the SMJLED PR2 using a warmer tint called the WPR2. See post #8 of this thread for more info.
SMJLED2 SS PR
To avoid confusion with the SMJLED PR2 This bulb from the Sandwich Shoppe has been renamed SS PR.
http://theledguy.chainreactionweb.com/product_info.php?cPath=48_52_82&products_id=853
http://candlepowerforums.com/vb/showthread.php?t=128801
Note the SS PR is 1/2 watt and all other LED lights Newbie has are 3W or better.
Edit: The SS Pr also seem to have a warmer tint than the original SMJLED. Beamshot comparison on post #52 of above link.
Edit: Newbie took an SS PR apart and it is not a Cree Xlamp die.
http://candlepowerforums.com/vb/showpost.php?p=1550782&postcount=40
EDIT: SMJLED PR 4cell is in production and will be availabe soon.
http://candlepowerforums.com/vb/showthread.php?t=130201
SMJLED 3mm
A 3mm LED together with a very thin boost circuit is required for the Solitaire.
SMJLED2 SOLITAIRE
http://home.mchsi.com/~lambda_lights/solit.htm
http://theledguy.chainreactionweb.com/product_info.php?cPath=48_56_83&products_id=861
http://candlepowerforums.com/vb/showthread.php?t=128807
MJLED CUT (BATCH 1)
MJLED UNCUT
SMJLED (4 die)
SMJLED CUT
SMJLED UNCUT
SMJLED PR(2)
EDIT Available now
EDIT: WPR2
SMJLED2 SS PR
SMJLED 3mm
SMJLED2 SOLITAIRE
