Tachyon
- Joined
- Apr 11, 2006
- Messages
- 92
Hi folks,
I'm curious to know whether any of you has tried to make a headlamp using the lamp assembly from a SL PP 4AA luxeon. I bought Dae's 3 Watt headlamp and surprisingly the lamp assembly from the SL 4AA is a snug fit in it provided you remove the existing LED circuit.
I'm trying to figure out a way to connect the wires from the headlamp to the SL 4AA luxeon assembly without having to solder it in place. That way I can remove the assemly and put it back in my SL 4AA body for use as a flashlight again when needed. Hopefully the circuit inside the SL LED assembly will function properly with just the three batteries.
I guess this setup will give the most throw for a headlamp! A diffuser can be used for more flood if needed.
I'd appreciate your thoughts on this.
Bopanna
Bopanna
