I was just recently fooling around with my light meter and taking readings using the ceiling bounce test. My Jil Intelli on burst puts out 10% more light that my FF3 on burst as measured by the light meter.
The FF3 was measured in an integrating sphere by ARC and the ones they tested got around 70 lumens. So I would say the Intelli exceeds that by a small amount. Note that my Intelli is from the first batch and the newer ones (that have been discontinued) may be different.
My Jil 1.3w with the Bus extension (with two alkaline batteries), puts out the same amount of light as my HDS B42 on its high setting. So I would say the Jil 1.3w puts out about 40 lumens. Note that this is also an older model and the new ones may be different.
One interesting note, the Jil 1.3w was quite a bit dimmer if just run with a single CR2 battery.
