Got mine 3/28/2006, ( NEW Improved switch model )
It is SN#000
133 , from Matt at BatteryJunction
It also had 3 shiney spot nicks on the head cooling fins
and a Sharpie marker won't get the job done
rubs off too easy / still looks like shinney crap 3 hours later
Their HAII won't stick on the sharp edges of the cooling fins
I use "AW's" PROtected RCR123a's (4.2v ea.) in mine
The instructions and warranty says you can .... so I do
Mine also has the "warm" yellow tint to it - which I don't like
I believe it is caused by the collimator lens that they use
Which is a hunk of polycarbonate plastic
Which must not be very clear and pure when they mold it
A quality piece of optical grade glass sure would improve this light
Course ... it would prob. add $60.00 to the final price too
Some of these are not properly focused to a nice tight beam-spot
You can find out by shining it on a wall @ 2 feet or up to 12 feet
If you see square corners in the beam-(spot) - it is not well focused
It will NOT throw a good distance if the SPOT is not tightly focused
I had to send mine back - with the insistance that it be tightly focused
That was my experience..... I do like it and use it frequently
But where can we get a pure/clear glass collimator focusing lens to put in it to improve the tint ?????
.................... TooManyGizmos ..
