VidPro
I got one of them ultrafire 1AAs
then i got the fenix 1AA that has 2 levels.
both of them are sufficient light, and the right size.
but i want ONE more thing.
i want a beam of light without the spill.
WHY?
because when you shoot it out into the bushes, it lights up everything
which messes with my eye iris, i want it to ONLY get to the target
a lot like that stremlight 4aa thing.
Most of my lights i use optics, there is less spill, but less spot.
for spotting things in the woods, only one single beam of light striking the target would be usefull.
I tried putting a refective tube around it, that sucked.
i know that a DEEP reflector would work, but i want it to remain VERY small.
i never thought i would want a side emitter, due to its inefficiencies, but that is probably what i need.
Did i mention CHEAP cheap small prefer levels, spot only.
the single AA lights are the first actual POCKET light, with enough juice, i need 1W of led power minimum, and as small or smaller than a fenix 1AA, must be way smaller than a mini-mag 2aa, which isnt pocket for me.
WHY?
