Well, i had burnt out the circuitry in my CMG IU like 2 years ago? and it was just sitting around. I just bought some k2s and 2 new 14500s and thought 'what the hell'. So i stayed late afterwork tonight (to use their shop) and made my own aluminum heatsink (nothin fany, just sits in the head, no threads) with a UWOP K2 being direct driven by a protected AW 14500.
I sanded the anodization off the reflector with 400 grit then tried to polish it with polishing paper. Came out ok, not too great though. I drilled a small hole in the front of the reflector to let more light from the led out, but i might have to drill another one in the back and look at securing the whole internals better. I'll post up beamshots later tonight if i can get my 'issue' fixed.
I'm thinking i have a bad connection somewhere because when the light is on, the output level fluxuates. You can see the output jump up, then drop down for a bit, then up then down. It seems to hold the same output level for a while as in it isn't an infinitely variable connection.
My other question is, am i at risk of burning this k2 out being direct driven? It is a 'N' bin so it is 4.23 - 4.47 volts. What about current? Do i need a resistor? Also, if i want to add 2 stage, what resistor would be good for 10% level?
EDIT: What everyone loves My first mod btw.
Canon S50:
1/500s
f/2.8 iso400
6"
1/30s
f/2.8 iso 400
6"
1/30s
f/2.8 iso 400
3 feet.
Reflector Shot.
http://allyoucanupload.webshots.com/v/2001227950639815649
Canon S50:
1/500s
f/2.8 iso400
6"
1/30s
f/2.8 iso 400
6"
1/30s
f/2.8 iso 400
3 feet.
Reflector Shot.
