During this latest blizzard (we sure have a lot of these around here), I took two new Brinkmann Rebels and removed the original LED assembly, saved them for future projects. The aforementioned 3/4 inch copper tubing caps were the perfect diameter, but about 5/16 inch too long to seat properly. I used a simple tubing cutter, and some patience, and shortened them, then drilled two small holed to pass #24 wires from the micro puck. Arctic silvered the white
(and later red, in my original prototype) onto the end of the caps. Wired teh black and red wires to the battery terminals in the plastic
"cup" that held the original LED assembly, ran the orange and green wires thru the little holes, and soldered them to the + and - terminals on the Luxeon Star (no puck meeded for the red LED) and pushed the new LED assembly into the cup part way, and then re-inserted it into the Rebel. Viola - it works. Next carefully ran a fine line of superglue around the inside of the bezel, carefully put in the NX05 optics,
being super-careful not to smear any glue on it,
and tried for fit. Had to push the copper pipe cap LED assembly in a little, try again, etc until everything fit and was in focus and the beam centered. Worked perfect! better than my original "75 cent" heatsink, and doesn't shift around when the light is dropped or whacked.
I then took the original one, removed the LED and 3 quarters heatsink, and put in a copper cap with red Luxeon star. Once again, all works perfectly. Nice simple mod, and reading this rambling dissertation probably takes longer than the mod will.
/ed B in the blizzard #2
