It's always frustrating to encounter a near-perfect product. A product that - with the currently-available technology - approaches perfect form and function, only to be denied that distinction by a single poor design choice. I refer to Surefire's decision to equip the U2 with a problematic, rubber-booted, mechanical, tailcap clicky.
Why not eliminate the clicky altogether? It ruins the superb intrinsic integrity of the tough outer shell of the U2, and introduces a reliability problem where none is needed. It could probably be done with a simple modification of the control circuitry, but even if another Hall Effect sensor were necessary, it would be worth it. Add a FET, or similar, to switch on and off. You would have, essentially, a 100% solid state light of superb reliability.
Think how much greater this light would be if you could just rotate the the level-control ring one more step, in either direction. From level one, or from level six, rotate the ring one more step to switch off. Then, when you want to switch on, you have a choice of the highest or the lowest output, depending on which way you twist the ring to turn the light on. Superbly simple and instinctively easy to master.
While you're at it, replace the now-redundant clicky tailcap with a solid, flat metal tailcap. Now the light can tail stand. Now the light has nothing to compromise the integrity of its outer shell - it could probably be dive-rated with no other changes.
At the least, Surefire should offer a variant U2 with these features. Keep the current 'tactical' model for those who need or want it. Add a 'solid state' model, for those who want the added reliability and simplicity.
