I wanted to post a few of my thoughts on the Kroma.
I just received the non Mil-Spec version from Seery:goodjob: this morning and I have found the following:
-Goatee
- The optic is greatly improved in my opinion over the KL1 optic as it causes the beam to have a hotspot and a useful corona. I like the KL1 but my initial uses of the Kroma cause me to prefer it to the KL1.
- The output on high is similar to the output of my McLux III PD. The beam is not as pretty (duh) but it is by no means ugly and it is certainly very useful.
- The output on low is rated at 15 lumens and there is no way that mine is putting out near that amount. I am not sure that this is a problem for me though. The output on low is similar also to the output on my McLux III PD and I find this to be an extremely useful setting. As the output is far less than what is rated, I would be expecting a far greater runtime than what is rated.
- The red and the blue LED's output is smooth and very different than the output of the Mil-Spec Kroma that I have seen. The 2 levels are about perfect with the low being really low.
- The selector ring has detents that allow the user to know when a change to the setting has been made without the light being on. This is a helpful and welcome feature in my opinion and one that I wish the U2 had (if it could be done effectively on the U2).
- The light runs on 17670 batteries (it will fit if you remove the outer jacket and replace it with packing tape). There appears to be no decrease in output but I have not had it long enough to verify this.
-Goatee
