clipse said:I realize its not a 6P but the G2 and the 6P use the same lamp and should be the same brightness.
clipse
carrot said:I'd post a beamshot, but it's not dark enough yet. Just FYI, the A2 is almost as much output as the G2/6P, but it does not throw as far (as my latest testing suggests).
Knight Lights said:Illum the nation,
It's not the same lamp. The A2 runs a regulated lamp at somewhere in the 4.5 volt range, (I can't remember the exact number), the G2 runs the P60 LA I believe.
Bill
Grox said:The A2 is the jack of all trades, but the master of none.
I got interested in LED lights because of concerns over incans unregulated dimming output and blowing at the wrong time, but the A2 brought me back to incans because it addressed those concerns, then added some low floody LED for good measure. I just get this sinking old Maglite feeling when I look at those dark yellow beams. My A2 cures that.Grox said:...the A2 lamp (MA02) is less likely to die when you turn it on because of the soft start. The regulation is a wonderful thing too.
The A2 is the jack of all trades, but the master of none. It isn't the brightest, the smallest nor does it have the longest runtime. It can be out-thrown by other lights but what it lacks in output it makes up in versatility. You really have to use the A2 to understand that it can replace 2-3 lights. The A2 has been engineered for utility and it excels in this capacity.
