I just received one secondhand. Neat little light.
Chris has an amazing assortment of tubes, tails, and a 27 mm head on his site as well. The head has a unique construction in that the LE screws into a module that threads into both the head and the tube. Only a small portion of this module (3/16" or so) is visible on the exterior. So the LE can either remain in the head or tube depending on what you're swapping out.
The tail is Aleph and E series compatible, so it's a cinch to upgrade to a McE2S.
The LE is compatible with Chris' KeyLux line and 0.55" boards. I immediately swapped out the LE with my TnC Li Lux V light, and ran an RCR2. It yielded a smoother beam than the AA Li Lux V.
The stock LE/reflector is impressive for a Lux I, very nice throw that belies the size of the head (20 mm). More than you'd usually demand from a pocket light. I reverted back to the original LE and a 2-stage Aleph trim tail with a clip attached. It makes a very nice pocket EDC.
An indication of the performance of the reflector is a comparison with a TW4 (L4 head on a single cell tube). Running Lux Vs and Li-ions in both, the output is comparable, but the deeper, smoother SF reflector yields a much tighter hotspot (for a Lux V). One thing I noticed is that the Li Lux V LE doesn't work with the 2-stage tail. It only comes on on hi.
Fit and finish is what you'd expect from Chris, his usual superb.
MSax, I know we're not helping with your search, just whetting your appetite more. It will be worth the wait.
