RofisLight
Results 1 to 11 of 11
Thread: HID Bulb change color
    Flashaholic* rizky_p's Avatar
    Mar 2006
    13th Colony
    Default HID Bulb change color
    My cars HID changed color. its originally 6500K but the right one has changed color, more like 5000K. what is most likely to couse it? power supply(voltage dropy)? ballast damage? or the bulb itself?
    thanks
    Flashaholic* iced_theater's Avatar
    Oct 2005
    Green River, Wyoming
    Default Re: HID Bulb change color
    So it went from a bluish color to more of a whiteish color? Usually HID bulbs change color over time, but it usually goes up in degrees K not down.
    Flashaholic* XeRay's Avatar
    Feb 2006
    Ogden, Utah
    Quote Originally Posted by rizky_p
    Is it a cheap Asian made conversion kit? 6500K is not OEM color so the bulb is most likely Asian made. All new cars come with 4200K.
    Mar 2006
    13th Colony
    yes. its made by korean manufacturer. been using it for 1 year...not sure it goes from 6500K to lower K. but the light has a slight green tint on it....
    Oct 2005
    it didn't have the green tint before?
    *Flashaholic* jtice's Avatar
    May 2003
    West Virginia
    Alot of HID bulbs will shift to a slightly lower K temp over time.
    Why one is shifting faster than the other, i dont know.
    ~John
    Oct 2005
    I've always read it the other way around. That they go up in K over time, but with bulbs made overseas it might do all sorts of things. There are a lot of aftermarket companies out now making HID bulbs for cars.
    Feb 2006
    Ogden, Utah
    Swap bulbs between both sides, see if the problem moves with the bulb.
    Apr 2005
    Gothenburg, Sweden
    Cheap bulbs change color more easily and if you are close to the end of the bulbs life, it's likley to change color.
    Still no response to that PM or e-mail you sent me two months ago? Try sending it again. I'm terrible at keeping track of messages.
    *Flashaholic* Illum's Avatar
    Apr 2006
    Central Florida, USA
    if your talking about the change in the tint of light, Doug [Quickbeam]'s made a logical explanation to that. On this review of the 24W HID from PTS
    http://www.flashlightreviews.com/rev...light_pl24.htm
    Quote Originally Posted by Quickbeam
    I did notice that if you wiggle the light around or point it face down the light changes color. This is due to condensed substances in the bulb entering the path of the arc. Generally when held horizontal the light was a bluish white, but when held vertically face down the light turned slightly orange.
    Hope this helps
    cheers
    Mar 2006
    13th Colony
    Xeray: kinda scary to swap bulb though. i am afraid to damage the left one. if indeed coused by damaged ballast. anyway i might try it.
    no it stays with the same green tint. does not change color because of the orientation. But its always like the original) when warmed-up.
