Klarus
Results 1 to 12 of 12
Thread: Excel question
    Flashaholic* Malpaso's Avatar
    Feb 2005
    MA
    Default Excel question
    Is there a way to have a cell read the last date/time the spreadsheet was changed? We have a number of people who access the same spreadsheets, and the spreadsheets change numerous times throughout the day (scheduling spreadsheets). The person who does the spreadsheet doesn't want to change the date/time manually each time he updates it. I know it can be done in the header/footer, but we only look at the file, and don't want to print it just to see if it's different.
    It's not that life is so short, it's that you're dead for so long.
    Flashaholic* Mad1's Avatar
    UK
    Default Re: Excel question
    Well the only way I know is that if you select the folder the Excel files are in and change the view to "Details" that should tell you when the file was last modified.
    Rightclick > View > Details
    But thats probably not much help to you.
    -=- Surefire G2 Yellow -=- Mag AA Opleac Newbeam -=- Milkyspit ML-1 -=- Surefire M3T -=- Mag ROP -=- Nextorch Magic Max -=- Fenix P1 -=- Surefire E1L -=- Fenix P1D CE Q5 -=- LEDWave X-33 -=-
    Apr 2004
    3rd Stone
    It's been a very long time since I've played with Excel and other spreadsheets, but it seems to me that back in the dark ages it was possible to create a macro to automatically get the current date and time and write it in a subfile. Things may well have changed since then.
    edit: Having just looked at a newer version, it should be possible to have a macro autoexecute and drop the current date and time into a cell. If you want to see the last time a file was changed w/o opening the file, that's an easier matter, easily done in the gui.
    "Show them a light, and they'll follow it anywhere..."
    Feb 2005
    MA
    Quote Originally Posted by Mad1
    That's actually part of the way to get it into the header/footer, but I can't find any way to pull that into a cell.
    *Flashaholic* greenLED's Avatar
    Mar 2004
    La Tiquicia
    Quote Originally Posted by Malpaso
    Right click on the Excel workbook icon just to the left of the File menu option, near the upper left corner of your screen. Choose the View Code option, and paste this in:
    Private Sub Workbook_BeforeSave(ByVal SaveAsUI As Boolean, Cancel As Boolean)
    Sheet1.[A1] = "File was last saved " & Now
    End Sub
    Got that from here. I tried it and it works. You can change "Sheet1.[A1]" for the sheet cell location you want the info to be displayed in.
    You can also use a macro to display the cell properties (I kinda like this one myself):
    Sub LastModified_LastSavedBy()
    'Keyboard Shortcut: Ctrl+Shift+L
    'put last modified date/time in current cell
    'put who last saved the file in next cell down
    On Error GoTo err_Sub
    ActiveCell.Value = "Last Modified: " & _
    ActiveWorkbook.BuiltinDocumentProperties("Last save time").Value
    ActiveCell.Offset(1, 0).Value = "Last Saved by: " & _
    ActiveWorkbook.BuiltinDocumentProperties("Last author").Value
    exit_Sub:
    On Error Resume Next
    Exit Sub
    err_Sub:
    Debug.Print "Error: " & Err.Number & " - (" & _
    Err.Description & _
    ") - Sub: LastModified_LastSavedBy - " & _
    "Module: Module2 - " & Now()
    GoTo exit_Sub
    End Sub
    Feb 2005
    MA
    Great! Thanks guys.
    The timestamp.html info might work but will take a bit of time. Using Now() will not work because that is simply the current date and will show even if no change is made.
    You could put a button on the sheet and run a macro from that which inserted the date and closed the file.
    Mar 2004
    La Tiquicia
    The macro I pasted gives you:
    you just need to add the button routine, or program it to run on close or something like that.
    Flashaholic slick228's Avatar
    Jan 2004
    Los Angeles, California
    Iím glad this came up. greenLED, do you know what is the macro to insert the tab (active worksheet) name in a cell? This feature is easily done on the Header and Footer, but I canít get the same information in a cell. Any help will be appreciated.
    Thanks!
    Mar 2004
    La Tiquicia
    Not off hand, but Google popped this up:
    http://www.mrexcel.com/archive2/29300/33399.htm
    ...a little more diggin':
    Function WorkSheetName() As String
    ActiveSheet.Activate
    WorkSheetName = ActiveSheet.Name
    End Function
    haven't tried that one, though.
    Jan 2004
    greenLED,
    Thank you for helping. Excel took the macro, but I canít get it to appear in a cell.
