Ok I'll give this a try. Maybe someone else can verify measurements.
Pix of light here:
https://www.candlepowerforums.com/threads/127383&page=2&pp=30
Length, front to back (
including rubber clickie): 4-3/8" This measurement with tailcap screwed loose enough that light isn't on. Rubber clickie protrudes about 3/16" from tailcap.
Diameter of bezel: 1-1/4"
Circumference of bezel: 4"
Diameter of tailcap: 7/8"
Circumference of tailcap: 3"
Diameter of section of light that protrudes out from light body toward clickie end (what the heck is it called? Thing that gives fingers purchase when holding in "cigar mode"): 1-5/16"?
Circumference of same section: 4"?
--This section is kinda hard for me to measure :sigh: The circumference appears the same as the bezel, but the diameter appears a little less. Anyway, it's close to the same as the bezel.
Hope this helps? Obviously I don't have calipers.
