I just purchased what will be the host of a 1W Cyan LS. It should look pretty cool and futuristic, hopefully it will have a nice scifi look to it with the LS.
It should arrive in the next week.
Now I must get the other parts ready. But I need to figure out what are best for my plans..
1st off is the electronics for it. It will be powered by 4 AA's. So I need to step down the voltage with a resistor. But then once the voltage drops below the LS rated voltage, would it be best if the resistor was no longer used, and then DD the LS?
If so, this circuit should do the trick right?
Or is there no advantage to removing the resistor once the voltage drops below ~3.5v?
<pre>
+++...........Q1.......|
Bat | | |
Bat |.ZDiode...|..R1...|
Bat |
Bat |
---..........LS-LED.....
|capcitor|
</pre>
Q1 = transistor (pnp, npn? I forget)
Zdiode = Zenier Diode, reverse voltage breaks down ~3.5v
R1= Suficient value to drop 6v down to 3.5 for the LS.
Capacitor is for a neat fade out effect when shut off.
So when the voltage is above 3.5, the Zenier diode breaks down and applies voltage to the Transistor to shut it off from DD the LS. Then the current continues through the limiting resistor. When the voltage is below 3.5, the diode doesn't break down and the transistor contiunes to DD the LS.
Will this work?
I'm thinking though that as the batteries approach being 3.5 volts, the LS will dim, and then when they go below 3.5 the LS will brighten up all of a sudden when it goes into DD mode. Am I correct?
Is there a better way to regulate this?
Secondly, I want the Optics for this to be as
tight of a beam as possible. Unfortunatly in this cool looking flashlight body, I can't fit 30mm optics.
Is a HD + NX05 the way to go?
Thanks for the help.
