zespectre
On a complete lark I picked up the "Eddie Bauer Dual-Color E-Light" (AKA the Coast "V2 6 Chip, Dual Color, Tactical Torch") from Target last night. I got mine for $26.99.
The light has 5 white nichia "Jupiter" LED and one red one. Two switches (reverse clickies) one for the white and one for the red. Runs on 3xAAA cells (in a carrier...ugh) and is manufactured out of a very light aluminium.
Build quality seems very good overall. The switches feel very positive with a nice feedback (even though I dislike reverse clickies).
I haven't dunked or wet this but there seems to be no real weather sealing around the LED's or the switches so I'd try to keep this unit dry.
The switches actually protrude from the sides of the light slightly, but the action is fairly stiff so I doubt that accidental activation would be much of an issue. Still you can unscrew the head slightly and that acts as an effective lockout.
No protective "lens" in front of the LEDs. However they are recessed a bit so scratching them shouldn't be an issue.
Now about the light.
The red mode is much brighter than I expected though the beam is marred by some terrible artifacts and dark spots. Still plenty usable but annoying.
The white mode... Holy Edison and Nakamura!!!!! I haven't actually metered this light yet but to my eyes it puts out a wall o' light similar to the Surefire L2 on high! The beamspread is (not unexpectedly) much like an Inova X5 but is very well aimed and even. This is a "light up the entire back yard" flooder with an -effective- throw of about 45-50 feet and an "I can see something over there" throw of much much further (I'd estimate 75-80ft).
The light body gets warm in the hand but not uncomfortable. The aluminum body definitely acts as an efficient heat sink. Again the behavior is very similar to a Surefire L2 on high.
If I have the time tonight I plan to set this light up and meter the output and then do a runtime on it (first for white and then for red mode).
EDIT on 8/25/2006
Did a runtime last night, the results weren't especially surprising to me. A pretty standard "unregulated" curve that took 2hr 5min to get to 50% and then flattening out at about 19% light into the typical super long LED "tail" at 4hr 15min. It stayed within 17%-19% until the 8 hour mark when I terminated the test.
That 17% is still enough light to read a map or find a keyhole in a house.
EDIT on 8/25/2006
