I got one of the 30 mm optics from Elektrolumens and was hoping to couple it with a 5W HD. Unfortunately, the couple 5W HD's I have are too puky green for me to consider using in a mod. I've been eyeing a proto KL3 bezel I got from PK and It looked like I could trim the skirt off the 30 mm optic and get a mate. I added a Q5 on sink from a destroyed KL1 and a BadBoy 750 to the mix and came up with an interesting mutt:
MORE INFO
The beam is certainly impressive and where real estate allows, I think it is definitely preferable over the NX05. I finished this mod early this morning so I haven't had much time with the light but tonight in walking around, it is a very impressive light. I did some comparative beam shots (L to R) with a Mr. Bulk's LGI, the mutt and a 1 W turbo:
I also took some lux readings at 39" with the following results:
LGI - 690
mutt- 1180
turbo - 3660
I feel very fortunate to have a couple of the Copia 168b batteries to power both the turbo and the mutt as a single 123 just doesn't have the butt needed for the BB700 and BB750. The higher voltage and capacity of the Li-Ion batteries seems to make a good match here. I suspect that a couple NiMh AA's would also work.
I want to thank Elektrolumens for bringing the 30 mm optics to us here at CPF and I think the part will prove to be a very acceptable and viable photon controller. It's too bad it has the lipped skirt on the head though. I hope I can get a good 5W HD in the future and another optic to try.
- Don
MORE INFO
LGI - 690
mutt- 1180
turbo - 3660
- Don
