1Watt Amber Pocket Light 3"x1"x5/8",Energizer 9V (8 Amber 5mm High Brightness)
I wanted a tiny pocket light that ran off a 9V battery. I was thinking of using a luxeon amber. Then I thought Sh*t, I need to make a power supply to step down the 9V input O.K. I already done that with my SkyLite rip off design which uses my ultra efficient 98% stepdown circuit which I also use to run my luxeons off any input from 4 Volts to 30 volts of input. Then I have to make a cutom lens. Forget It! 8 Amber, 30 degree 5mm High Brightness Leds, a switch, and a 9V battery, Done! It's cheap, it's bright, I like very much! Too many round lights out there, I like square lights can you tell ? This thing feels great in your hand and its well balanced. It measures 3-1/16 long by 1 inch high and 5/8 inch wide. It draws a little over 100mA from the 9V battery.
Top: 1 Watt luxeon star, 98% eff. Step-down circuit, any input from 4.0 volts to 30 volts of input.
Middle: SkyLite Rip-Off Alternate from 2 white leds to two red leds, dimmable, 98% eff. Step-down circuit, 9 volt battery.
Bottom: 8 amber high brightness leds, 9 volt direct drive.
