ianb
This is my first mod, I'm mostly just pleased that it works! Its a...
Mag 2D body and head
Lux V WW0T
McR-45 Reflector
Downboy 750mA converter
6 x NiMH AA Eneloops ~8V
H22a Heatsink (very simlar to Hotlips)
The main motivation of all things was seeing H22a selling lux V heatsinks! I had a Mag 2D I had bought as a PR based SMJ LED host( good excuse ) and thought, 'why not?' I like Lux V lights (my first light I really saved for was a Surefire L6 and I have had good associations since ).
The first problem I came across while making it was I had to move the heatsink inside the body because of the length of the McR-45(used because I love my HD45). So instead of the heatsink sitting with a lip around there edge at the top I had to sand and file this off so it would move about 15mm inside the body.
Next I received the reflector, is was a fairly good fit into the Mag head, only requiring gentle sanding.
The next part of the adventure was learning to solder , with the aid of a new soldering iron(Weller WTCP51) I got to practising. I was sure at one point I'd screwed the tiny little converter board, but they are obviously made to put up with newb's like me . **As an aside, I was a little stupid maybe, but you should have seen my face when I opened the bag holding the converter :huh: , how small they were!. I thought they were about twice the diameter**
Another problem was that as I was lowering the heatsink I had to cut down the switch and original bulb holder, removing the spring loaded mechanism and cutting down the plastic tower to leave room for the converter and heatsink.
I kept the switch and soldered from this to the downboy and through the heatsink to the WW0T.
I had a wait for a couple of days for epoxy and was keen to see if it worked, it did nicely, but I left it out and I think my daughter must have played with it for quite a while as next time I wanted a quick peek :thinking: nothing? Sadly that was the end of the lux , luckily I'd bought 2
Today the epoxy came and now I have a complete light, the plan was this to be a glovebox and possibly infrequetly used light so I got some Eneloop as they hold their charge well. I got an 8 x AA holder as there wasn't a 6 x AA for sale at the time, so I soldered a wire across 2 to allow use with only 6.
The head showing McR-45 and WW0T
The heatsink lowered into the body
This shows very roughly the beam, ceiling shot from about 2 feet
The battery pack
I had originally wanted to do a Royal Blue lux 5, I got that together and it was really impressive, but I swopped out for the WW0T as that would be more useful. I am going to get some more hosts and plan some more colour Lux V mod's(Royal Blue, Cyan, Green)
Thanks for looking, I'll try and get some beamshots tonight,
Ian
Lux V WW0T
McR-45 Reflector
The battery pack
Ian
