andrewwynn
click pic for the album of pictures.
I've been wondering a long time just how much resistance the mag spring has.. since even in my baddest (well most of them) mag mods i still use the stock spring.
So i finally took a miliohm measurement (the standard way.. jam an amp of current through it and measure the mV drop)..
the results... FORTYFIVE MILIOHMS! holy cow! That is more than double the entire resistance of my hotdriver circuit! Definitely more resistance than the smartpak and 'holy yikes' in general.
I took a piece of 1/8th inch wide solder wick and not even soldering just wedged it between the spring at the top and the bottom.. and it chopped off 2/3 of the resistance.. down to 15 miliohms! (0.015 ohm).
So.. guess i'll be performing that mod in the future on all my lights... I'll probably use the scrap wire i pull off the KIU ceramic sockets.. 16ga wire is 1/3 miliohm per inch.. So that will be perfect..
let me see.. with a 100W light and 9.5A.. that means.. 0.42V dropped on the spring.. that boils down to 317Lumen loss on a 64625 lamp!
anybody know a silver-plater?
I've been wondering for a long time 'cause steel is just a terrible conductor.. there seems to be some coating on them but apparently not silver (what it should be).. I'm surprised it took me so long to actually get the measurement. I've been just thinking that it's a pretty thick wire even if it's steel.. amazing once the numbers are actually calculated..
re-working for a mag85: 3.35A x 0.045ohm = 0.15V.. that's a difference of 38 lumen... 10.65 vs 10.80V.
Well one more thing to mod, folks... get out your soldering irons.
(oh.. ps.. sand first.. you'll not have much success soldering to that spring before sanding!)
-awr
