I've read of some having problems with their Arc-P's not working. The old bit of aluminum in the bottom of the tube fix. My first CMG I.U. is having not serious issues really, but it blinks on and off at a point where it didn't used to. Still works, but it occasionally blinks. Is the front-end twisty on some lights causing a problem if tightened too hard? I noticed the circuit bord on my I.U. has a small space around it now, like it's been pushed up a bit. Maybe by cranking it too tight against the battery? Is this an inherent potential problem with this type of light? Any particularly bad culprits susceptible to this? Thoughts? Ideas? Maybe tail cap twisties not so bad? Though they seem to have their issues as well.
