As a big fan of "small"/pocketable (<1" diameter) single cell CR123 LuxIII lights, I've managed to amass a collection of them
. Many beam measures later, here they all are in one place for comparison.
All data is based on output after two minutes on a fresh cell, using the recommended cell for the light (RCR123 for the FF3 and the Rainier; primaries for all others).
The "% lumens in 10 degrees" is an indicator of each light's designed beam tightness - i.e. how much of it's overall output is directed within 10 degrees of beam center. Higher percentages reflecting more emphasis on throw; lower more on flood.
The "% drop at 5 degrees" is an indicator of how dinstinct the center spot is - i.e. does output drop off rapidly as would be the case of a tight spot with a distinct edge, or does it fall slowly providing a more gradual transition form the spot.
[EDIT 9/4] In the plot above it's hard to tell if differences in the lights in the spot region or in the flood region are due to differences in the beam design/profile, or just due to differences in total output. To get a more "pure" look at the beam profile itself I made the same plot, but normalizing each light to the same total output - I used 30 lumens as my normalizing point (used 20x instead of 10x scaling for flood). In other words if each light is set to, or allowed to run down to, a total of 30 lumens output, this shows how the beam is distributed across its width. A different - and I think more telling / comparable - picture of beam profiles:
You can draw your own conclusions, but here are some interesting observations/distinctions to me:
Actually I'm wondering where the truly wide/flood beams (such as the L4) are in this class??? Anyone know?
(Wish I had a Pierce....
...... how wide IS that wide beam???)
Inputs on the means of summarizing welcomed. I'd like to make this as useful as possible!
- FF3 is the total output winner, with runner-up the U60, albeit at relatively low runtime on max for both (note all runtimes except the FF3 are from FLR -thanks Doug!). These are the only multi-level lights in the bunch (20 levels available) - best to use these at lower levels and run on max only as needed. Lowest total output: Surefire E1L.
- Peak Rainier is the throw champ followed by the E1L and the U60.
- Fenix P1 has the widest beam, followed by the U60. Narrowest beam is the E1L.
- The E1L is the "spottiest" beam by far (almost all output w/in 10 degrees of center).
- The "floodiest" beams are the Amilite Neo and the FF3, although not a huge difference across all lights except the E1L.
- The FF3 has the most gradual transition/drop from the center spot (least distinct hot spot edge).
