[ QUOTE=scooter ]Craig, I have MS VirtualPC setup on my computer at work. Tuesday I will test whether I can run freeview.exe to display a graphic in the virtual machine. The virtual machine runs in a window, so if the graphic displays I can then capture the window from the real computer session.
If it all works like I think it should, I will let you know and you can email the files for me to capture. Post here if you find a better way.
scott[ /QUOTE ]
Hi Scott,
These are not graphics files; they're what's known as RIPScript files, requiring a DOS program called FREEVIEW.EXE to view as graphics.
As an example, here's a full-screen RIP picture of Barney the Dinosaur in a courtroom:
!|1K|w0010271610|c08|W00|=00000003|L004XBJ5K|LBK5KBK5X|LBK5X0055
!|L0055004Y|L007ZHR7Z|L8T7W006N|c06|LB05XB07W|L8W5T8W7T|L785O787L
!|L5O5K5O7D|L4G5H4G77|L395E3971|L275C276W|L195A196P|L0E560E6M
!|s3J4F6F6R6Z71717206|FAP5P08|F3A7O08|c08|L541P9L1P|L9G1R9G4U
!|L9G4U554U|L554U551Q|L561P501P|s6N5Z4R2D4R5Z6N7306|F7E3X08|L9I2WD32W
!|LD22WD233|LD2339G33|LCW34CW4U|LCW4U9G4U|s304Q5Y155Y4Q300H06
!|B9Y3GCD4H|=00000001|L9X3GCD3G|LCD3GCD4I|LCD4I9X4I|L9X4I9X3G
!|s422110422110422106|FC23908|S0107|FAY2Z08|L2F0C2F40|L2F402K40
!|L2K3Z2K0C|L2F0C2J0C|c0E|C2H0805|S010E|F2H080E|c08|L2E0E270G
!|L270G1X0N|L1Y0N1R0Z|L1R0Z1T17|L1T171O1I|L1O1I1K1R|L1K1R1L20
!|L1L201H2F|L1H2F1C2M|L1C2M1B35|L1B351I2Y|L1I2Y1M2V|L1M2V1P34
!|L1P341Y2S|L1Y2S272N|L272N292B|L292B291Z|L291Z291P|L2A1P2E1M
!|L1L2V1K2W|L1L2W1P2N|L1P2N1U2J|L1V2J1U2A|L1U2A1X22|L1X221Q1T
!|L1Q1T1L1N|L1O1O1X16|L1X161U0W|L1U0W220O|L220O2F0K|L1R1S2218
!|L2118200X|L200X2C0O|L1U1W271A|L271A2310|L260Z2F0S|L2310260Z
!|L2A0P2E0O|L1V21271H|L281I2B1B|L2B1B2813|L2A132F0Y|L1N2X1S2O
!|L1T2O1Z2H|L202I1X28|L1X28221Y|L221Y2D1I|L2C1I2D1C|L2D1C2D1C
!|L2D1C2F1A|L1N2Z1Y2N|L1Y2N232H|L252H2227|L22272422|L2422271Z
!|L271Z2A1X|L1P321R2X|L1R2X212N|L202N252K|L252K2527|L24272A21|S010F
!|F220Q08|L2B112715|F2B1008|F251W08|F1T2W08|S0104|F280H08|F1T1608
!|F1U1408|F1Y1K08|F231S08|F292808|F272708|F1S2M08|F1W2P08|F1W2Q08
!|S010F|F1W2M08|F2C1L08|S0101|F1L2H08|c0F|X1J2I|X1N2F|X1K2C|X1N2B
!|X1O29|X1R29|X1P26|X1P23|X1S24|X1O1Z|X1O1X|X1C2Z|X1I2V|X1F2V|X1G2S
!|X1I2R|X1F2O|X1J2N|X1K2Q|X1R2G|X1O2H|X1O2L|X1G2J|X1L27|S0107|F2G2M08
!|c08|L2K402V41|L2U413144|L31442R46|L2R462A46|L2A462045|L20451Y44
!|L1Y442341|L23412740|L27402K40|s7367736N6V7371720E|F2C4208|LEQ2THR3A
!|LHR3AGQ5X|LGQ5XDQ4W|LDQ4WEQ2S|LDI4TGX61|LFU5OFI7I|LFI7IFL7J
!|LFL7JFM7J|LFM7JFZ5P|LGU5KHB6K|LHB6KHE6K|LHE6KHG6I|LHG6IGX5E
!|LER59DT6E|LDT6EDU6G|LDU6GDZ6I|LDZ6IEW5B|LES3HF23J|LF23JF83O
!|LF83OFI3R|LFI3RFQ45|LFQ45FX4A|LFX4AGB4G|LGB4GGP4J|LGP4JGY4P
!|LGY4PHC4V|LHC4VHI50|LHI50HI53|LHI53HG56|LHG56HE58|LHE58HA58
!|LHA58H657|LH657H253|LH253GS4X|LGS4XGN4W|LGN4WGC4S|LGC4SG24O
!|LG24OFT4L|LFT4LFL4E|LFL4EFE47|LFE47F840|LF840F13Z|LF13ZEU48
!|LEU48EQ49|LEQ49EQ46|LEQ46EU40|LEU40EU3W|LEU3WEO3R|LEO3REK3M
!|LEJ3MEI3I|LEI3IEK3F|LEK3EEN3D|LEN3DEP3E|LEQ3EER3F|LER3FEU3H|S010F
!|FF94U08|c00|=00000003|LG64VG64V|LG64VG84R|LG84RG74M|LG74MG94J
!|LG94JGB4H|LGB4HGG4G|LGG4GGH49|LF345F73Y|LF73YF63W|LF63WF73T
!|LF73TFA3R|LFA3RFE3R|LFE3RFI3S|LFI3SFM3L|BHA5GHG5Q|c0F|=00000001
!|LHB5FHF5F|LHD5EHD5E|c08|LHD5DHD56|LHC56HA51|LHB4YHD4V|LHD4VHH4W
!|LHH4WHI4Z|LHI4ZHG50|c04|Y02000400|@HB5GA|S0107|FE16808|FFP6T08
!|FH46208|c08|L9Y2TA22N|LA22NA62I|LA62IAD2F|LAD2EAL2C|LAL2CAQ27
!|LAQ27AT25|LAT25AZ26|LAZ26B326|LB327BC25|LBC25BH24|LBH24BM26
!|LBM26BR27|LBR27C429|LC429CM2A|LCM2AD32A|LD32AD928|LD928DE28
!|LDE28DG2A|LDG2ADE2D|LDE2DDB2D|LDB2DD92D|LD92DD92F|LD92FDB2F
!|LDB2FDA2H|LDA2HD62I|LD52ID32G|LAE2UAJ2Q|LAK2PAQ2M|LAL2TAO2M
!|LAK2UAM2S|LBW2WBU2N|LBU2NBQ2I|LBQ2IBK2B|LD32GCT2G|LCT2GCA2F
!|LCA2FBT2D|LBK2CBU2D|LAT24AO21|LB725BF2D|LBF2DBD2B|LBD2CBK2M
!|LBK2MBQ2R|LBQ2RBR2U|LAS2UAT2Q|LAT2QAV2K|LAV2KB02G|LB02GB22C
!|LB22CB226|S0102|L9U2VA02Q|FB02J08|S0105|FAS2C08|FC12B08|LBG23BR21
!|LBQ20BV1X|LBV1XBX1R|LBX1QBV1M|LBV1MBQ1L|LBQ1LBI1J|LBI1JBB1I
!|LBB1HB51B|LB51BB317|LB317AV16|LAV16AM17|LAM16AE18|LAD17A71D
!|LA71DA91J|LA91JA61Q|LA61QA41V|LA41VA920|LA91ZAH21|LAH21AN22
!|LAU21B322|LB322BF21|LBF21BM1Y|LAU1ZB51Z|LB51ZBJ1V|LBK1XBR1T
!|LBI1UBQ1S|LAV20AP1Y|LAV21BH1Y|LBG1YBL1Y|CAI1G03|CAW1D03|CAU1T02
!|CBK1N02|S010F|FBB2008|FBI1U08|FBI1W08|S0105|FB61M08|LBA1HBF1L|c0F
!|LAW1DAW1D|LAJ1GAJ1G|BAP1QAY1W|c08|CB21R02|S0100|FB21S08|FB21R08|c00
!|LBB1GBH1L|LAU1TAN1S|LAN1SAI1P|LA41AB112|LAV14A618|c08|O760T00A00I0M
!|O6V0O00A00302|O7C0N00A00302|O751300A00B01|L7M147U16|L7U16861B
!|L881C8J1I|L8J1I8Q1N|L8D1F8119|L7J0G7D0I|L7D0I760G|L760G710I
!|L710I6Y0J|L6X0J6T0G|L6T0G6M0H|L6L0H6R0G|L7K0E7M0D|L80167W0X
!|L7W0X7W0Q|L7W0Q7S0I|L7S0I7O0D|L7O0D7K05|L7K057A02|L79026X01
!|L6W016N06|L6N066G0D|L6G0D6G0K|L6G0K6D0S|L6D0S690Y|B6R0A730G
!|B73097J0F|B74067E0B|B6R07740A|B6J0G6S0I|L6T0G6P0I|C5C1902|L5D185H19
!|L5A195G1B|L5N165I1I|L5I1I5B1G|L5B1G521F|L521F5810|L58105D10
!|L5D105K11|L5L115P14|L5P145K1C|L5N165S16|L5S165T13|L5T135O0Z
!|L5O0Z5D0W|L5D0W530X|L530X5210|L52105713|L4V1F511F|L5H1H5N1K
!|L4U1F4T1G|L4T1G4V1I|L4V1I531K|L531K5B1L|L5B1L5L1L|L5L1L5N1K
!|L5L19651I|L5K1D611J|L5T1C5T1C|L5W1A5T1D|L5W1A5Y1A|L5Y1A5Z1C
!|L5Z1C611B|L611B631D|L621D651C|L651C651G|L651F6E1L|L6E1K6K1N
!|L5Z1J641I|L5S1H5U1L|L5U1L5Z1K|L5Y1L621L|L661J611M|L6N136O12
!|L6P146H17|L6H176B19|L6B19641A|L641A601E|L5R1H5K1K|L5J1L5E1N
!|L680Y6614|L6614661A|L65156610|L7Y13871A|L871A8A1D|L6X1D711M
!|L7E1C7C1N|L7C1G761M|L761M6X1G|L6V1E6Q1J|L7E1F7K1J|L7K1J7J1B
!|L6P1I6P15|L7J1H7L16|L740R730U|L730U710X|L710X730X|L720Y740Y
!|L750Y760X|s2D0Y0Y6211620Y0Y00|B7I0D7N0G|L7K0H7G0H
!|s002D0G3H0G2D002D0F|F710708|a0C13|S010C|F751608|F5X1C08|F5V1I08
!|L651J681H|F621F08|F611J08|F611K08|F721G08|S010F|F7G1D08|L6U1E6Y1C
!|F6Q1908|L6Y1Q6Z1J|F791L08|s002D0G3H0G2D002D0F|F821808
!|s3S3S3S6W3S3S3S3Z0F|F731308|S0108|F5P1D08|F5C1508|S0107|F571I08
!|F5C0X08|c09|LD023D922|LD922DG22|LCY1ZD81X|LD81XDI1W|LCU1VD71R
!|LD71RDI1P|LB40ZB50U|LB50UB70U|LB70UB90W|LB90WB30Z|LAQ0WAS0S
!|LAS0SAQ0Q|LAQ0QAN0R|LAN0RAQ0Y|LAA0WA80T|LA80TA50S|LA50SA30T
!|LA30TA30V|LA30VA90Z|LA90ZAB10|LAB10A90W|S010B|FA50V09|FAP0S09
!|FB70W09|c07|LEB533M53|LHJ51HR51|c08|L4954ED54|LHJ52HR52|LB25XB27X
!|LAX7WAX5W|L8Y7V8Y5Q|L8Y7Y8Y7S|L8V5R8V7Y|L7A5O7A7L|L7A7M7A7K
!|L757L755M|L5P7E5P5I|L5L7D5L5I|L4H784H5G|L4D774D5E|L3A723A5C
!|L3672365C|L286X285B|L246W245A|L1A6S1A58|L166S1658|L0F6O0F57
!|L0A6N0B6N|L0B6N0C55|a011C|a0109|a0410|a031C|S0103|LAX7XAW7U|F9X6Y08
!|F7V6K08|F6A6D08|F4U6A08|F426908|F2L6208|F1M6208|F0T6208|F005Z08
!|FCH6A08|c00|Y02000500|@E54EE|@EC4HX|@EJ4JH|@EQ4MI|@EU4PB|@F14SI
!|@F64UT|@FL50'A'|@EP2YPR|@F530OS|@FK33EC|@G035UT|@GE38IO|@GS3BN|S010F
!|BHC5JHL5T|LHD5JHJ5J|LHH5IHF53|c04|Y02000400|@HE5JA|c07|L004VBN5J
!|LBN5JBN5Y|LBN5Y0056|LB45YB47X|L905S907V|L7B5N7B7N|L5Q5K5Q7E
!|L4H5I4H78|L3B5F3B72|L285C286U|L1A5A1A6R|L0G580G6Q|L006N006N
!|L006O9B7Y|c0E|Y08000100
!|@0389''Well, of course that stick is fossilized, you idiot\!
!|@038T . . . I'm a dinosaur\!''|c08|L004U4553|LE9533S53|LHI51HR51
!|LAA11A20V|LA20VA40R|LA40RA80Q|LA80QAC0Y|LAC0YAA11|LAQ0YAU0R
!|LAU0RAQ0O|LAQ0OAK0P|LAK0PAL0S|LAL0SAQ0Y|LB010B90Y|LB90YBA0W
!|LBA0WB80T|LB80TB40S|LB40SB20Y|LB30YB010|C2H0805|LAA18AJ15|LAJ15AX14
!|LB015AW14|LAZ15B517|LB517BF1J|LA71ZAN23|LAN23AR23|LAR22AR26
!|s4Q2D4Q2D4Q2D4Q2D08|FCA1608|FHI4L08|c00|L003V2E3V|L2L3V513V
!|LCY3XE53X|LHH3WHR3W|L003Y2D3Y|L2L3Y523Y|LCZ41E341|LHG3ZHR3Z
!|L00422242|L2X435343|LCY47E147|LHF46HR46|L004A524A|LCX4FDZ4F
!|LHC4GHR4G|L004M524M|LCX4ODS4O|LH94PHR4P|L224XDU4X|LHH4ZHR4Z
!|L003T2F3T|L2K3T533T|LCY3VE73V|LHH3YHR3Y|=00000003|L003Q2E3Q
!|L2K3Q533Q|LCY3SE73S|LHK3UHR3U|c07|L004UBM5K|LBM5KBL5Z|LBL5Z0056
!|L004WBK5O|L0052BI5Y|L004ZBK5T|LGD4DGD4D|S0105|BAE17AX18|BAL16B017
!|BB51AB71E|c05|LAF17AX15|LB61BBE1K|LAC19AG1A|LB419B31B|c00|=00000001
!|LBD1HBG1M|LAT24B027|LB027B826|LB826BG25|LBG24BK22|LAO2NAR2K
!|LBL2CBI2B|s4Q2D4Q2D4Q2D4Q2D08|FAG2T08|LAJ2VAO2P|a020I|LAR2UAS2P
!|LAS2PAV2K|LAV2KAZ2H|LAZ2HB12D|LB12DB228|LB926BC2A|LBC2ABG2G
!|LBQ2UBP2R|LBP2RBM2N|LBL2NBG2H|c08|=00000003|OBL5S00A00309
!|s4Q2D4Q2D4Q2D4Q2D00|FBJ5U08|FBK5U08|c00|XBL5Q|XBK5R|XBK5Q|XBN5J|c0B
!|=00000001|LD21ZD61Z|LD61ZDD20|LDD20DK23|LD21TD81T|LD81TDE1U
!|LDE1UDM1W|LD21PDC1P|LDC1PDK1Q|LDK1QDQ1R|S010F|BBD1YBK1Y|c0F
!|LAV20BB1Z|LB221BE1Z|LB320BA21|c08|LBG21BM1X|c05|LBJ1YBQ1X|c0F
!|LH053H84O|c08|FF83R0F|LH957H454|LH454GY50|LGY50GF4U|LGG4UG14P
!|LG14PFS4L|LFS4LFK4E|LH054H74P|FH75208|c00|=00000003|LHH51HG55
!|LHH55HC58|LHC58H756|LH756H152|LH152GS4Y|LGS4YGJ4W|LGJ4WG84S
!|LG84SG04Q|LFZ4QFU4N|LFT4NFM4H|LFM4HFH4A|LFH4AFC43|LFC43F841
!|LF841F540|LF540F040|LF040EX46|LEX46ET4A|LET4AEQ4A|LEQ4AEO48
!|LEO48EQ44|LEQ44EU3Z|LEU3ZET3V|LET3VEP3R|LEP3REK3O|LEK3OEI3L
!|LEI3LEH3I|LEH3IEI3F|LEI3FEL3E|LEL3EEM3D|LEN3DER3E|LER3EEW3H
!|LEV3HEW3J|LEW3JF33J|LF33JF43M|LF53MF83N|LF83NFC3P|LFC3PFG3Q
!|LFG3QFK3R|LFK3RFL3U|LFK3UFL3Z|LFL3ZFN42|LFN42FT47|LFT47G34C
!|LG34CGB4F|LGB4FGK4I|LGL4IGR4L|LGR4LGZ4P|LGZ4PH54R|LH54RH94U
!|LH94UHE4X|LHE4XHI51|c09|LF047F441|LF541F43W|LF43WF43T|LF43TF83S
!|LF93SFE3S|LFE3SFI3S|LFJ3SFM3K|LG64WG34Y|LG74UG64R|LG54RG64N
!|LG64NG84K|LG84KGB4J|LGB4JGH4I|c00|LF13ZF740|LG34RG94U|LGK4IG94E
!|LFK3VFE3O|a0A12|S010A|FFR4A00|FFP4D00|FFR4D00|FFW4D00|FFY4E00
!|=00000001|LEI3IEX3R|LEX3RFC43|LEK3GF33R|LF33RFJ47|LFJ47FR4G
!|LFR4GG84R|LF23MFD3W|LFD3WFT4C|LFT4CG64M|LG64MGM4S|LGM4SH350
!|LH350HC56|LG44CGJ4L|LGJ4LGV4R|LGV4RH54X|LH54XHF53|LEU3ZEX41
!|LER42EU45|LFZ4BGA4K|LGA4KGS4S|LGS4SH34Y|LH34YHE55|LFC3QFK3Z
!|LEQ3REX3V|LEX3VF03Z|c09|=00000003|LG34ZG94U|LG94UG74Q|LG74QG84M
!|LG84MGB4J|LGB4JGG4J|LGG4JGN4J|LGO4JGR4C|LF43ZF43X|LF43XF63T
!|LF63TFA3T|LFA3TFG3T|c0E|Y02000300|@GV04TEL|=00000001|LGW06GR06|c08
!|XGX06|XGW06|XGY06|XGY06|XGZ06|XH20A|XH206|c0A|XGW09|XGW0A|XGY0A
!|XGZ0A|XH00A|XH30A|XH40A|XH50A|XH60A|XH00A|XH10A|XGZ09|XH309|c08
!|XGX0A|XGX0B|XGY0B|XGY0A|c00|XGX06|XGY0B|XGY0A|c08|XGX0B|c0A
!|LGW0AGW0F|LH50AHB0A|c04|LGW0FGW0C|XGW0F|#|#|#
As you can see, the graphic is composed of ordinary text characters designed to be transmitted over phone lines by a dial-up BBS.
