A while back I purchased an L5 and L6 with the Z58 tailcaps. Because I planned to use them in a "tactical" capacity, I changed the tailcaps over to the more reliable and safer Z41s, and stored the Z58s for later use. In the process of setting up a C3 for Utility purposes and stocking my storage case with extra parts (and thereby checking that all of the parts worked properly on "everything"), I discovered that some of my Z58s did NOT work on "everything". I have two Z58s, and one Z48 that function on everything. I also have 3 Z58s that only function on a 2-battery body or on the C3 body, NOT the L6 or M3 bodies?! If you include the Z59 (or equivalent) on the U2, that makes 4 that don't work on the L6/M3 bodies?! I also have a spare Z59 for the U2 that will work on the M3 BUT NOT the L6. That's 2/7 for the Z5x series, and 3/8 if you include the Z48. I have heard about reliability problems for the Z58 BUT 28.6% ?!?!?!?!
I tried to bend the tabs upward on one of the malfunctioning Z58s as I have heard others talk about doing, but this did not help. I also broke one of the "very stiff" tabs off although this did not affect the function on the 2-battery bodies or the C3 body. Function remained unchanged.
So, I am admittedly confused. Do I call Surefire, and if so tell them what??? "Your L5 tailcap works fine if you leave it alone but it won't work if you try to transfer it to an L6/M3. Another tailcap that I bought works fine on a 2-battery body and the C3 but not on the L6/M3. The U2 tailcap works fine if you leave it alone, but won't work if you try to transfer it to an L6/M3. The Z59 works on the M3 but not the L6." Their website says that their Z5x series tailcaps and Z4x series tailcaps are interchangable on everything!!!!!!
All of my Z58s have three tabs in the tailcap for cap-to-body contact.
By the way, the new Z73 "lockout" tailcap for the G2 works on everything and it costs $12.00.
Thanks for your help
Flashdark sends, confused.
