DoubleDutch
Yes, it's there. Bring out the wallets!
Kees
Kees
warpdrive said:Hmm, how would this thing be compared to say a, Gerber Infinity Ultra?
TinderBox (UK) said:did you know, you could have got another 5% discount by using discount code CPF5 at the checkout.
that is a everlasting CPF member only discount code.
regards.
NutSAK said:Output should be similar. The EO of course is much smaller and the EO's runtime, although very good for a AAA light and well-regulated, won't be as long as the Gerber.
amanichen said:Are you sure about that?
Can I have some of what you're smoking? :huh2:NutSAK said:Yes. My Gerber Infinity Ultra will output useable light for over 36 hours. You can see from the EO runtime chart that the light is out at 20 hours. Note that the flashlightreview states the IU at 25 hours "peak brightness".
As I stated though, the EO has better regulation, so it does have a more useful runtime to 50%.
amanichen said:Can I have some of what you're smoking? :huh2:
"25 hours peak brightness" is the manufacturer's advertised runtime. Manufacturer runtime claims are notoriously inaccurate.
The runtime graph on for the infinity shows that at 15 hours into its run, it's only around 12% of original output. How does this performance equate to "25 hours peak brightness" or "36 hours of useful output"? Are you running lithium batteries in your infinity?
Bullseye00 said:The E0 is AAA and the GIU is AA - It's not a fair comparison. It's also not fair to compare how much space they take up in your pocket. The E0 has the advantage in that comparison.
