These lights seem fairly similar in size but they are different in some respects.
Output:
- E1: 12 lumens [Fenix]
- E0: 5.5 lumens
Runtime
- E1: 1h45min
- E0: 11h
Size:
- E1: 2.85" (L) x 0.55" (D)
- E0: 2.66" (L) x 0.47" (D)
Price:
- E1: $24
- E0: $20
Quality edge for E1: AR coated lens and nicer styling.
So which one would you chose if you could get only one? The E0 is slightly smaller and trimmer, but is that enough to make a difference in the pocket or on a keychain? The E1 should be clearly brighter. The E0 seems dimmer than an Inova X1. Sure, a runtime of 11 hours is great, but isn't the nearly two hours of the E1 more than enough for a keychain flashlight running on inexpensive AAA batteries? Isn't the brighter output of the E1 preferable? As to the price, the E1 is 20% more expensive, but when that's just $4, does it matter that much? Finally, doesn't the E1 look much nicer?
It seems to me that the only pros of the E0 are a long run time and slightly smaller dimensions. Any thoughts?
Output:
- E0: 5.5 lumens
Runtime
- E1: 1h45min
- E0: 11h
Size:
Price:
- E1: $24
- E0: $20
