js
*SOLD*
I have a 7.2 volt 2.4AH Li-ion pack with PCB protection. This is the pack made by www.batterspace.com shown here. It is made from LG Chem 2400 mAh 18650's and a PCB protection circuit. However, the pack as received was a reeking piece of crap. The damned PCB was held on by SCOTCH TAPE, if you can believe that. So I re-did that portion of it, and shrinkwrapped the whole thing, silicone jacket wires, kapton tape, and so on. And it even has molex connectors on the ends of the wires which will grab the ends of Welch Allyn lamp pins, or most standard LA pins, such as the TL LA, SL-20X, etc. But don't get your hopes up, however, as the stupid PCB will prevent you from driving any even remotely powerful lamp--which it sees as a short circuit. You could, of course, by-pass the PCB, or try some other trick. Or remove the molex connectors and use it to power something else, an LED light perhaps? Whatever.
Point is, I'll sell this for $10 to whoever wants it. The cells are in perfect condition, and the pack is better than what batteryspace delivered to me for $24. Rip-off, that was.
And that's not all . . .
I also have two loose LG Chem 18650 Li-ion cells. I liberated these from a 3 cell batteryspace pack, which wasn't much better made from the 2 cell version. I had to by-pass the PCB to do a direct-drive runtime test against a PWM regulator, and I had to carefully monitot the voltage to prevent over-discharge during the process. But I digress . . .
Point is, that these cells have weld marks where I ripped the tabs off them, but a little work with some 220 grit sandpaper will fix that. The shrink wrap is unharmed and in good order. The cells are in perfect condition, with only a handful of cycles on them.
I'll sell these for $4 each.
Shipping will be $2 for one or two of the loose cells, or $3 for the pack alone, or the pack with one or both loose cells. i.e. you want the pack, $3 shipping. You don't want the pack, $2 shipping. Unless of course you don't want ANYTHING, in which case, what the hell are you reading this for?
I will accept PayPal to *address removed* or check or money order.
:nana:
:nana:
