Anyway to print screen in xp?
TinderBox (UK)
England, United Kingdom
the easiest way is to press the PrtScr button above the insert button and then go into xp`s built in paint program in accessories and then edit,paste.
regards.
elgarak
Florida
After PrtScr, you can paste a copy of your screen in nearly any application (Word, PowerPoint, Photoshop, you name it).
PrtScr or Shift-PrtScr copies your whole desktop. If your desktop is extended over two screens, it copies both screens.
Alt-PrtScr copies just the active window.
cobb
I just hit print screen, past it in word, resize it as needed and print. Quite a few folks at work who dont use computers and its the easiest way for me to get the info to them than using the apps built in print function.
danielo_d
NorCal
Also, if you hit ALT+PrintScrn, it'll only capture the active application window. Works great for documentation purposes. You don't get the whole screen that you would have to later crop out.
Regards!
Danno
