I have myself several Ultrafire lights sitting here, all suffer the same issue:
bad contact in the tailcap, causing the lights to flicker or shine with lower brightness..
First thing i tried, was to screw down the retaining ring in the tailcap; worked for a while, but then the issue was back.
Then i made new solder blobs to the switch pcb; worked for a while...
Finally i bended a piece of 0,5mm wire and soldered it to the pcb..
The lights work fine now, without any flickering.
