abvidledUK
Why would you want to use Blue LED's, not UV, Blue ?
Is that really true or just hearsay.Flash_Gordon said:Blue is useful in forensics or in hunting.
Hunters use blue lights to follow a blood trail. It makes blood drops stand out as very dark nearly black spots against any background.
Mark
cobb said:I didnt try it, but wondered how successful it would of been to pull over someone when I had to drive a chevy montecarlo the silver model similar to the state cops if I had my blue light and flashed it out from the front window.
Sub_Umbra said:Blue light has traditionally been used in technical theatre because . . . it is a very easy color to mask from an audience.
I can't give a scientific reason. From a practical side I can say that most of the time when we wanted to hide light from the audience we would use some type of black fabric with a nap. On the cheap end it would be something with a very fine nap, typically black Commando Cloth. If one had a bigger budget something with a deeper nap like a black velvet could be used and the deeper the nap, the less light will be reflected by it.beezaur said:Sub_Umbra,
Why is blue easier to hide from the audience?
Scott
beezaur said:Depands upon your goals.
If you are looking for "3 hots and a cot" for a while followed by an assortment of dead-end jobs when you get out, then sure, it works pretty well.
Sub_Umbra said:IMO whichever fabric is used the 'splash' from a blue light is much easier to soak up than the splash from a white light. As I said, I can't give any scientific explanation for this but most theatres I've worked in seem to operate on the same principal. I've seen a number of examples of white light hitting black velvet where the black velvet looked absolutely, positively, stark raving white from the audience and had to be dealt with to 'knock it down' one way or another. It sounds impossible but it does happen -- and sometimes it can be almost breathtaking. Mildly similar things can happen with blue light but they aren't nearly as severe or extreme and may always be dealt with in a simpler fashon.
cobb said:They work well for those with near side ness, I know from experience. If you are far sighted like one of my coworkers who tried my blue inova light, it makes things blurrie.
MicroE said:I would guess that blue is easier to hide from the audience because of Rayleigh Scattering.
It's the reason that the sky is blue during the day. The blue photons from the sun are more easily scattered from their initial path and "bent" toward the surface of the Earth.
Thus, at a distance, the blue light looks dimmer than the exact same power red light because the blue photons spread out faster the further you get from the source.
