Bmccue1964
I have a 6 volt lantern at home that I would like to drop a 1 Watt Luxeon (PR type) into from a Sear's light. The Sear's light runs on 4 - AA batteries. The 6 volt lantern is one that is powered by a single 6 volt (26,000 mah) battery. It can easily be made to have positive polarity at the bulb tip and does also have a metal reflector.
My guess is that the lantern should run in the neighborhood of 240 hours on high. I do know that Sears also sells a 3 Watt lantern that takes a standard 6 volt lantern battery. However, I have yet to locate run time figures based on a 26,000 mah (26 AH) battery.
My question is:
Will I be pushing too many amperes into the bulb to cause heat issues?
My question is:
