Smith, J
As noted above if you are going to use alkaline then the L2P head w/ L1P body is a great choice. Go to fenix-store.com and click on his L2P/L1P offer. There are intensity/runtime graphs there comparing the L2P, L2P head on L1P body, and the orignal L1P. I don't know how many lights he tested to get this info, but it clearly shows the L2P head on L1P body (ie 1-AA bat) to have greater brightness, runtime, and superior regulation. I bought one and am really enjoying the 1-AA configuration for around the house use. The 2-AA configuration gives a lot more light for more demanding jobs. If you like to use ni-mh or lithium then the L1T has good regulation and I think it is a little brighter than the L2P head/L1P body. Nimh batts in the L2P/L1P increases it's performance as well (extra hour or runtime in the 2-batt configuration). If you use alkalines get the L2P head/L1P body. If you use ni-mh either light performs better with them, but the L1T will be brighter and has 2 levels. The stand alone L1P has inferior performance. See flashlightreviews.com for additional info on these lights and many, many others.
Kippers :candle:
