MacTech
I just recieved my Terralux UV 1 watt upgrade module today and dropped it and the supplied reflector in my new host Minimag, overall i'm impressed, but i'm also a little dissapointed, the supplied reflector throws a wide, and *exceptionally* ringy beam pattern, yes it's brighter than the $7 Lighthound 12 LED UV light, but it's not $30 brighter, i don't know whether to be impressed with the Lighthound rig or dissaponted in the Terralux....
the Terralux *does* seem visibly dimmer, as it's putting out more longwave UV than visible light, the Lighthound light puts out more visible light than UV, but i just can't get past that....ringy....beam of the TL, the LH light has a smoother flood of light at the expense of output
just for kicks, i removed the head of the UVMag, then grabbed my MiniMagLED 3AA and twisted it's head off (insert appropriate screaming sounds here ), and screwed it's head down on the UVMag....
not only did the head fit (it just has a shorter amount of travel, 2.5 turns to remove the head), it also cleaned up the ringy beam *dramatically* *and* created a much tighter hotspot, the TL UVMag now actually *throws*
so now i have to find a way to source out a head, reflector and window of a MiniMagLED, i e-mailed one of the official Mag Instrument parts suppliers about purchasing the parts if they were available, it seems a waste to have to spend $23+ just to get the *head* of a MMLED, which is all i really need....
unless.....
how difficult would it be for a guy with *no* soldering experience to desolder the Cree LED module from the Terralux disc, desolder the LED from a MMLED 2AA, and drop the Cree onto the MMLED LED module thingy?
unless.....
