IsaacHayes
I've hooked up my old trusty Dell XPS D266 PII to my network and I'm in the process of pulling all my old files off. Mostly Photoshop stuff (good stuff, I need to show off or finish), and old games I still like to play, and fonts, and nifty programs (some of which are no longer on the internet to download!).
Anywho, I tried to see if my USB stuff would work with drivers on this old Win95C box, as I saw it had 2 USB ports on the motherboard. Well the cables/etc won't even fit in the holes!!! I tried turning it around several times, then making sure I had it in the right way, but the holes are just TOO SMALL?!
Did the change from USB1.x to USB2.0 change the size of the connectors?
I could find no info on the net about this...
Random Ramblings: 1). I hate how Dell formated the 8gig HD on this beast to be in 4 FAT16 partitions. Their answer was "so old dos disk compression programs would still run". Who needed that on a new box with Win95C and an 8gig HD (one if the biggest you could get at the time)? I should of formated the whole thing when I got it, as it was always a PITA to run out of space on C, then un-install programs, and re-install them to D, E, F. Ugh. Now it's even more a pain getting my files off. It's like they are spread out over 4 computers. I'm not even sure if the machine came with a windows95 CD, that may be why I never wiped it when I got it.
2). I do however like how fast this machine is, for being so old. Win95C runs very fast on this machine, almost instant response like my new P4 machine with XP. I've got windowsME installed on a way faster machine and it's a lot slower!! Specs, 160mb RAM, PII 266mhz, 8gig IBM HD, CD drive, Sound Blaster Gold PCI, 33.6kbit US robotics hardware modem, 100mbit network card, Pure3D-II voodoo2 3D card, STB Velocity 128 video card, and I think the motherboard runs at 33mhz bus. I ordered the XPS machine pretty bare, and added the 3d card, sound card, 128mb ram stick, and network card. The monitor is a 17" trinitron, with a aperture grill. Very sharp, VERY flat!! Compared to other normal CRT's, this one blows them away. It is limited in the resolution/refresh rate though. It's old, and I'm still using it on my new machine. 1024x768 @ 85hz. (must have 85hz, so no higher resolution is used).
Any whooooooot!
What about the USB thing?
Any whooooooot!
